Light bar switch install
  • Thread starter Thread starter Mdegen93
  • Start date Start date
Nice to see one done, I actually went down and explored and this was on the list. My only issue is I need a spot for 3 switches, I have light bar, ditch lights, and backup lights on my list. Which bar are you running?
Link to switch, or did this come with the light bar?
Nice what bar did you go with.
Spoke with baja and they said their kits should be rolling out soon, s8 for the affordable and the onx6 for bad ***.
Yes but I believe they made their own bracket.
I'm sure the s8 will work but the onx6 has some meat to it to put out the light. The s8 is plenty good too I'm sure.
Looks like the Baja kit is out and ranges from $ 675 - $ 975 for either the S8 or ONX6 kits. Comes with 20" bar, brackets and wiring harness. Just the bar ranges from $ 579 - $ 770.
Well any 20” bar should work with what I have now as long as the dimensions are the same
Do you like the little 6” bars right on the side of the ram decal tho? Thought it looks sick. And would you recommend to go bigger on the lower part of the grille? Like 20”
Yeah I like the look of the 6” lights. They are a bit of a flood light. The lower is 20” but if you want good output go with the Baja kit. I’ll be upgrading my bar in the spring
