Any rebels with 6inch lift?
Ruben73
NJ
Anybody with a rebel with a 6 inch lift on 22's with 35's? Did a search and did not see anything
Not sure about that exact combo, but there are a few 6” kits around online.
I have the 6” BDS on my ORP which has the same factory ride height as the Rebel. Very satisfied. I optioned up the Fox rear shocks and BDS UCA’s. My 35’s are on 18” Fuel Vectors.
Did you have to replace the UCA's or was it by choice? Thanks for the reply
I was considering 6" RC lift. Thought about BDS but a few guys told me RC is decent unless I want to hit hard core trails then go with something else.
That was purely my choice. But the ball joint angle is perfect so I felt it was worth the upgrade.
RC 6 inch on new rebel
Did the RC lift maintain any of the rake? I personally like the rear of my truck to be a bit higher than the front. I contacted RC 3 days ago and am still waiting on info to see if it will still have a higher rear after the install.
Did your stock cross memeber have to be cut off or any stock parts? Was it all remove and replace? I wanted to keep my stock parts. On Monday they will start on my truck. Thanks
6” procomp kit (full kit), 325/50r22, 22x12
You can’t return it to stock, you have to cut the crossmember on all kits.
I’d think you’re in 37” territory with a 6” lift, depending on how far you want to stick your wheels out. My rebel is on air, but I only brought the nose up 2” and fit 37s. 35s should be no problem with just a level and that minor front wheel well mod if needed.
I finally did it after months of going back n forth.
6 inch RC
4p70 4Playwheels 22x10 brushed gunmetal
35 x 12.5 x 22 Nitto Ridge Grapplers
They should. When you say recalibrated what exactly do you mean though?
If it’s the stock ones, they should just continue to work.
