Motofab 2" Front and 1.5" Rear kit
Eric326
Hey everyone,
Couldn't find much for pictures showing a Motofab 2" FT / 1.5" Rear spacer kit installed, so I figured I'd post a couple up just in case anyone else was interested. Forward rake is about 1", which is what I was hoping for since I tow with the truck.
** First picture is stock, the rest are after the Motofab lift **
ColoradoCub
Calirado
Looks good. I went with the motofab 2” and then ordered a 1” spacer for the rear to get a little rake back.
mstenvold
Hey everyone,
How is the ride? I always hear everyone dog the space that goes on top of the strut vs one that requires disassembly and goes on top of the spring...
Eric326
Obviously ride quality is a bit subjective in regards to what everyone describes/observes, but overall it is still very similar to stock. I've noticed a slightly stiffer ride over bumps in the road though. As a comparison, this truck still rides smoother/softer than my 2015 Ram 1500 with air suspension did though.
Alxmlr789
Yes, it sits at the bottom.
Thanks, eric. I just bought a 1.5" motofab for the rear, trying to figure out if it is the same as the 4th gens, which i think it is. Do you have any photos of the kit ?
Eric326
I don't have any photos, but yes it is the same one as the 4th Gen kit. I ordered off of Amazon, but reached out to Motofab prior to ordering. They confirmed it was the same kit.
Alxmlr789
Cool, thanks!
W13NY
New York
Hey everyone,
Did you do new UCA's too?
Eric326
I didn't change out the UCA's. After seeing that they were the same as the UCA's used on the air suspension setup, I elected not to change them. After install I felt comfortable with ball joint and overall angle. But, I don't have the ORG option, so it's just 2" over stock ride height.
W13NY
New York
Yeah I dont have ORG either. I bought the Motofab 2" Level Kit but didnt have it put on yet was getting opinions from everyone on here before deciding if I should do UCA's. So far no one has said I need them with the 2" so I am going to go ahead with the install in the next week or two.
I'm just very cautious because when I purchased my truck I had to have the ball joint replaced since it was defective from factory. Just nervous about another mishap that could be caused by me this time.
Eric326
Yeah I hear ya, I tried to dig through this forum quite a bit on deciding whether I needed new UCA's as well. The water got muddy as well in regards to what, if anything, was different in regards to stock UCA's versus the Mopar 2" Lift UCA's.
