ANY UPDATES ON BILSTEIN OR FOX LEVEL STRUTS OR COILOVERS FOR 2019 DT RAMS
Tipsterpfd
Anyone have news or updates on BILSTEIN. 5100 or FOX leveling struts for 5th gen dt.
Thanks in advance
I just checked Bilsteins website and saw they now are listening 4600's for the coil sprung DT's.
I reached out to Rancho about their quicklift a few weeks ago, they said "a couple/few months." Basically we might see them by Xmas.
Should not be long now for the 5100
No it shouldn't be. In the installation instructions tab it shows a 7 position height adjustable 5100 with height measurements for both normal and orp.
I can't find a place that sells the Bisteins online.
Is this for a 2019 DT or are you just showing a 5100 in general?
This diagram was attached to the pdf for DT Bilstein 4600s. The last 5100s I had only had 3 settings, not 7, & no ORP settings. So I'm assuming it's a peek at their new, but not released yet, 5100 DT. But you can make whatever ya want out of it.
The 4600's do not specify 4wd or 2wd. I guess they could be the same.
Shockwarehouse.com lists both stating they are for 2WD without ORG or air suspension. $102 for the fronts, $76 for the rears, which is $356 for the set.
