I hand washed my 2 week old limited last weekend and found several defects. First I'm mad at myself for missing these before accepting delivery. Then I shake my head at how these things leave the factory with what should be obvious defects during assembly. Seems sloppy and pride in work was lacking.
First is a dent under the chrome trim. Hard to see in the picture, but there is no way this was done after the trim was applied.
Next is what appears to be a thumb print or other finger. I'm not even sure if this is paint or what, but once you see it you can't unsee it!
My truck is patriot blue, but you mostly see my wife's white Toyota reflecting. What should be obvious is the ~24" swipe in the paint on the rear passenger door. Not sure if its in the color or clear, but under the lights of a paint booth should not of been missed.
There is a paint chip exposing bare metal on the driver side retractable step. The steel cables on the tail gate are also different lengths, one cable is holding all of the weight of tailgate while the other is showing slack.
If these obvious defects made it out of the factory on a $64K truck what's hiding underneath? I ordered this truck to my specs and now I'm feeling a bit of buyers remorse.
