troutspinner
I had time today and finally measured the Sound on my Alpine System and thought I would post for people thinking about speaker / system upgrades.
The Setup
Vehicle: 2019 Ram Crew Cab
Head Unit: 8.4c (Stock)
System: 9 Speaker Alpine with Subwoofer (All Stock)
Software: REW (Mac)
Microphone: Dayton Audio UMM-6 USB (Calibrated)
I did three (3) sweeps. System Volume was set at 20, EQ was Flat, Fade Centered and Surround Off.
The Mic was placed at the driver’s headrest for all measurements.
I measured from 20Hz to 20kHz three (3) times and then averaged those sweeps for consistency and then smoothed the average to 1/24 to make it a little more pleasing to the eye.
Here is another graph of the same above settings but the front and rears measured separately. The Green is the Fronts, The Blue, Rears. You can definitely see a large volume difference when sitting in the driver’s seat.
It looks pretty good from a flat perspective but a picture from 20Hz to 20kHz can be very deceiving. Below is the “big” picture.
30Hz to 80Hz isn’t bad, only a 7dB variance but then there is a 18dB drop at 105 +/- Hz from an aggressive crossover slope I assume. Mid-Bass is pretty beefy up to 300Hz and then the system stays somewhat balanced from 400Hz to 6kHz. 6kHz to 10kHz has a 5dB decrease which isn’t too bad but then at 10kHz to 20kHz it has a pretty aggressive 20dB drop off.
So, there you have it. A visual representation to what your ears are hearing with the Alpine System. After seeing this, I can understand why people are changing out their dash speakers, better sensitivity to increase the 6k and up range. We do however have that all powerful 3 range EQ, LOL but if you increase your Mid to make the music height to your liking and then adjust Treble to please your ears you should find a nice spot, I know it sounds pretty good to my ears with just +3 on the EQ. I did not however make any measurements with where I like my EQ, sound is a very individual thing and seeing a graph based off of my settings won’t tell me anything my ears already know.
Just a quick note: While I show “Surround Off” on some graphics, the measurements did not make a difference with surround on or off. I assumed they would not as these are just sweep measurement sounds.
If you have any questions about specific frequency ranges, let me know, I can pull up the measurements and get some numbers if you need them. I'm not a total REW geek as it can get pretty complex but I've enjoyed using it in the past to find natural crossover points and help me EQ my DSP(s) on former builds.
The Setup
Software: REW (Mac)
