Any chance you could share where you got the parts along with the part numbers?So just wanted to give you guys the updated pictures after I received the new bezel today. Everything works perfectly. Next step I'm going to ask the dealership if they can load the app to control the heated steering wheel from the screen. Let me know what you guys think.
Looks good! Did you ever get the heated steering wheel working?So just wanted to give you guys the updated pictures after I received the new bezel today. Everything works perfectly. Next step I'm going to ask the dealership if they can load the app to control the heated steering wheel from the screen. Let me know what you guys think.
So looks like Infotainment is getting ready to release the 12" screen upgrade this week or next. I got an email for a webinar on Thursday to introduce the product. From my recent conversations with Infotainment, the 12" upgrade will cost somewhere between $3,000 - $3,500, which IMO is too high. I might hold out and see what the 8.4" upgrade will cost and might go that route.
Tac747 do you have dual zone climate control?Just ordered the 8.4 non nav. $1699.00 includes the bezel and trim. Wasn't about to spend an extra $1000 for nav that my phone can do better.
8.4 non nav $1699.95
8.4 Nav. $2699.95
12". $3999.95
No I do not.Tac747 do you have dual zone climate control?
When you get the parts, can you confirm the mopar part number for the parts included in the Infotainment kit?No I do not.
I will post the part numbers when I get it. Just today I received the tracking numbers and it should be here Friday.When you get the parts, can you confirm the mopar part number for the parts included in the Infotainment kit?
That is pretty nice. I had been unable to locate a brand that was compatible but Now that I have spent $1700 on the infotainment setup, every manufacturer out there will have a compatible system on the market.I went the aftermarket route.
Here is a pic of the current set-up, without the new bezel. As you can see, you can temporarily use the 5 inch bezel, however it does not sit perfectly flush and you are missing the manual tune and volume controls. The compass feature at the bottom of the screen is there, but doesn't work because the plug is different. Once the infotainmment Siruis XM upgrade kit comes, the compass will regain functionality.Had to use the dash kit from a 4th genThat is pretty nice. I had been unable to locate a brand that was compatible but Now that I have spent $1700 on the infotainment setup, every manufacturer out there will have a compatible system on the market.
I received the infotainment upgrade today.View attachment 34086Here is a pic of the current set-up, without the new bezel. As you can see, you can temporarily use the 5 inch bezel, however it does not sit perfectly flush and you are missing the manual tune and volume controls. The compass feature at the bottom of the screen is there, but doesn't work because the plug is different. Once the infotainmment Siruis XM upgrade kit comes, the compass will regain functionality.
Good to know. Do you have the part number for the panel? I believe it is located at the top and should start with 5YU.I received the infotainment upgrade today.
I can verify the radio PN 68292209AF
The bezel PN 68340283AC
There was some really minor scuffing on the top of the instrument panel that was supplied and it had more of a shiny finish than the flat black top that came with the truck. I was going to keep my original panel and just replace the bezel with the supplied 8.4" bezel but 2 of the attachment points and the alignment posts do not line up so I was forced to use the supplied panel. Hopefully you will not run into this problem. I was considering cutting the alignment posts and connection points off but for the time being decided to leave it alone. Hopefully my OCD will let me. I attached a picture showing which screw post and alignment tab is the problem. The original 5" measures 2-1/2 inches center to center. The 8.4 measures 2-5/8" That must be why infotainment sends the whole instrument panel instead of just the bezel.
View attachment 34235View attachment 34234
