Painting Bumpers on 19 limited
Talon Nelson
Does anyone know that this can be done right without any peel? Same goes with the window and door handle trim? Looking for a friend
Also anybody that has done the paint or wrapping, has it stuck on? Would you recommend it?
Painting over chrome is not an easy task. It can be done but it takes a lot of prep and if not done correctly it will chip and peel easily. The best way is to grind off all the chrome but that's not cost effective if your going to pay a shop to do it. You'd probably be better off getting new paintable bumpers and go from there....Same for the handles. If your lucky the handles may come in color from the factory. You can call your local dealer to find that out.
Steve
Wrap it. Color will not match 100% in direct sunlight but i think you can almost not see the difference. My friend did it to his bumpers and window frames. Dont know how will it work on door handles since its not smooth
