Disconnected negative battery terminal issue- SOLVED
Hockeygod1225
Disconnected negative battery terminal while installing vararam intake. Once reconnected and started up I am missing all settings including my controls for heated and cooled seats, steering wheel etc. Anyone have a clue how to get this back to normal?
Did I read cycling the ignition a few times so it gets it brain back together somewhere on another thread? Maybe worth a try.
Will give that a try. Did it twice but maybe it needs more.
Maybe have a short drive and see what happens after letting it rest for a bit, certainly I've read it can take a few goes or a bit of time before it sorts itself out but I can't think what thread I may have been reading.
It just takes time. Start it up and let it run a minute. Then let it sit. Overnight usually works. I wouldn't worry unless it's more than 8 hours.
It should be back within an hour or two. I had to touch the key fob to the start button while starting to bypass the anti theft screen.
