6.7 data plate
Wayniac85
Hey, guys n gals.. Anyone have any idea where the Cummins data plate is on the 18-19 6.7s? Had a 97 dodge 2500 and it had a 5.9 12v and the data plate on it was on the side of gear plate out front, a little stainless/aluminum plate with the engine info on it.
Thanks in advance!
Thanks in advance!
You may have better luck in the 4th gen side of the forums, or in the HDRams.com forum, as this section of the 5th gen forums pertains to the DT half ton trucks.
Unsure if they still do that? I don’t remember ever seeing it on the 6.7s. There’s a serial number cast into the block, kind of behind the turbo if I recall. But other than that? I don’t know. They would know on Cummins forum for sure.
