I have a Lonestar (ie. Bighorn) with a 2.5" level and can tell you now you’ll rub on the UCA’s with stock +19 9” wide and 12.5’s, and super close on an 11.5" wide.
I ran 285/65’s (11.2 wide) on the stock 20x9 +19’s for a bit and there was about 1/2” of clearance between the tire and UCA’s.
You'd have to come out further in order to get 12.5’s under without rubbing anything on the inside and then you start to hit on the edges of the fenders.
I just tried to mount my 285/65's on my leveled truck on a 20x10 -19 and even that was rubbing on the edges of the fenders..
I am planning this exact setup - 2.5" level, 35x12.5x20, on stock 20" rims (+19 offset). Should I plan on having spacers (1" or bigger?) on hand just in case, or absolutely?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
