Looking for a way to lower the front
zsbills
I'm looking for a way to lower the front end I've already done the 2'' drop on the rear and would like to lower the front 2'' and maybe the back some more. I seen one only kit for $1300 with a 3-4 week back order. Does anyone have any suggestions?
Using stock struts from a 4th gen will likely lower the front 2-3” as the spring perch sits lower. Same with 4th gen Bilstein 5100s. At max 2.7” setting they appear to be close to stock 5th gen struts.
thank you ill try to find a decently price stock strut. i'm not doing a very good job of googling today.
Check out IHCsuspension.com for a 3/5 (below) and 4/6 option.
That looks great! I'll have to look into that.
Edit - Will it work on a 4WD? I don't necessarily need all the ground clearance. Just don't want to get stuck. :D
2WD only at this time, but he’ll get a 4WD kit out eventually.
Gotcha! Thank you sir.
I’m holding out hoping someone comes out with. 2/4 drop.
