ExcursionDiesel
- Jul 8, 2018
Doesn't Tow mode disable MCDS? Or is that just Start/Stop also?Not sure if I understand what you are talking about based on your comments above. You can NOT turn off the MCDS but you can turn off the Auto Start/Stop feature. You can "trick" the MCDS from turning on if you manually set the gear limit but that is the only way I am aware that it can be temporarily turned "off".
