Easy entry - disfunction?
Hannibal19xx
Is it correct, if i lower the ram with the key fob, Open the Dir After loading in my stuff, Start the engine and the airsuspendion doesnt pump it up to normal automaticlly?
Gesendet von iPhone mit Tapatalk
It should raise when you hit 15 MPH. Sorry I don't know the KPH equivalent.
Why ever it doesnt
Some have reported issues like yours but I don't recall ever seeing a fix. My Limited allowed me to drive above 15 MPH still in E/E mode once but ever since it has always raised back up. A "reset" via battery negative disconnect, wait 20 minutes, then reconnect is about the only reset anyone knows of. You could try that.
