4th gen uca vs 5th gen uca
Ethanww94
Does anyone know of the 4th gen upper control arms will work on a 5th gen truck?
Sounds like you've done your homework. Can't wait to see the results!
Do you know if anyone has ran a 4th gen coilover set up on a 5th gen?
Not that I am aware of. The struts are different for 5th gens. The spring seat sits much higher. So if you use a 6” coil over it may work but you would only get 3-4” of lift using it on a 5th gen.
