Mopar 2" Lift 77072424 Instructions
Billet1500 4x4
California
Does anyone have access to Mopar instructions on how to install the 2" lift kit? Seems easy enough to do. Just need to get the truck aligned after. I did hear somewhere that the dealer also adjusts the headlights after the install...
https://www.bamwholesaleparts.com/oem-parts/mopar-2-inch-lift-kit-77072424
I want to see how hard it would be to do on my own to save the $400.
  • Mopar DT 2 inch lift.pdf
Bhbdvm
western NC
Do you know if this is the same part number as 77072424AB? What is the difference if installed on a truck with the off road package ? Thanks
brian42
San Diego, CA
I read on another thread that some people have complained about the lack of front end lift for the kit and that there is a spacer that can be added to the front if it doesn't lift enough.
The "AB" kit has this spacer already installed.
What is the difference between the 77072424, 77072424AB, and 77072424AC? I see you mention a spacer installed on the AB version.
brian42
San Diego, CA
There's a big thread on the Mopar 2" lift and they talk about that in there. Looks likes even if they change a supplier for a part in the kit it gets a new number:
