Turning radius? Can this be improved with wheel offset or it is what it is?
JeffK2019
I think I know the answer but figured I would toss it out there.
It's only been a week for me and my new Limited - but wow the turning radius I think is just horrendous. I am coming out of a Suburban, which is no small vehicle, and it would turn dimes around the 1500 Limited.
I do plan to add aftermarket rims/tires at some point - can wheel offset impact the turning radius at all or is this pretty much a suspension issue and I live with what I have?
I think my U turn days are over...........
trixdesigns
Look at the wheelbase.
2019 Suburban: 130"
2019 RAM 1500 Crew Cab: 144.5 - 153.5"
You're looking at over a foot more in the smallest bed size (unless you've got a quad cab).
JXL118
California
I'm with you. I'm coming from a Nissan Titan and i definitely think the Ram's turning radius feels a lot bigger than the Titans. Titan wheelbase was 140.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
I sometimes really miss the four-wheel-steering of my old GMC (with Quadrasteer).
Billet1500 4x4
California
2 largest factors on turning radius both of which are fixed. Wheel base and steering angle
3corner
I drove a 2015 Tacoma prior to buying a 2019 Ram, the turning radius on the Ram is terrible, I scratched my front passenger rim 3 times making a U-turn scrapping the curb. I have the factory OEM 22 wheels. Cost me 85 bucks to repair it. I should of went with the 20 wheels. 22 low profile tires suck so bad, I have to be careful when I parallel park or U turn from now on, which suck because on my Tacoma I never had a problem even if I scrapped the curb.
Biga
Cincinnati
The Ram has a better turning radius then the Ford or GM trucks, obviously if your coming from a car or SUV you will have to get used to a long wheelbase vehicle.
SilverSurfer15
To answer your actual question, not in a positive way. The more negative offset, the worse it gets, either because it rubs at full turn or just simply because the tire is out further which increases the chance of hitting something like a curb. The only thing you “could” do is grind back the steering stops, assuming that’s what is stopping it. But then you risk over stressing a few parts, I think a lot of this comes from non truck owners buying trucks, turning the wheels all the way full lock (especially dry turning), and complaining about wearing out CV and tie rod ends. So now they limit it.
The turning radius on this truck is SO MUCH BETTER than f150, I could NEVER make a u turn in the ford, even ridiculously large ones (3 lanes and a shoulder). This truck I usually can make the medium sized ones (normal two lanes) as long as I pregame it a bit.
moosem
Rhode Island
The turning radius on my '15 GMC sure seemed way better than my RAM. I have to 3 point turn backing out my garage down my driveway in my RAM. Never had to do that in my GMC. Roughly the same wheel base.
Neurobit
RAM Sorcerer
Texas
So you’re comparing a compact truck’s turning radius with a much bigger RAM 1500? :rolleyes:
Biga
Cincinnati
Only way to get a tight turning radius in a 1500 is to buy a regular cab short bed, I had one in college and that thing would turn better then some cars.
rsmeanie
Bay Area, CA
Yup, like ^^^ he said, give it some gas and whip the backend around. Nice and tight.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Comparing crew cabs, the Ram has a 0.1’ smaller turning radius than the GM trucks...all but identical. The F-150 is a couple of feet worse. The Tundra is slightly better than the Ram.
Sadly, none of them hold a candle to my old Quadrasteer (4-wheel steering) GMC. The system cut more than 5 feet off of the turning radius, compared to these trucks...and that was a crew cab with a 6.5’ bed. It was a fantastic idea that never gained enough traction to be profitable.
