8.4" to 12" upgrade
I am looking to do this also. I was thinking of calling my local service department to inquire. Unless making the switch yourself is ridiculously easy, I'd most likely have them do the work anyway.
It’s super easy. I just want to make sure it plug and play and I don’t need a new computer module for it
Believe it’s little more then plug and play. But doable
From what I found the screen is an easy install. Then I need to download the new software which is also easy. Only think I can find an answer to is if the module is the same
Its a hdmi or high speed cable goes from radio/hvac to processing module.
There's another thread on this and they got pretty close... I believe that the volume and tune knobs were the only things not working.
So you know what the thread name is? I can’t find it
Where do you get the software? And has anybody figured out how to check the SW version on the 8.4” non-Nav?
Infotainment.com sells the complete kit
They’re out of their damn mind
