cgraydotcom
- Jan 5, 2019
Switched out the tires for some 275/60R20’s. Kept factory black wheels. Added 1.500” wheel spacers. Leveling kit goes on next week.
Great set up hopefully I'll get mine looking like that soonSwitched out the tires for some 275/60R20’s. Kept factory black wheels. Added 1.500” wheel spacers. Leveling kit goes on next week.
What brand spacers did each of you go with and who did the install? Also, I've seen some posts about having different size on the front and back. Do you feel that yours being the same size they stick out the same from the wheel wells or are the different front to back? It's hard to tell from the picture angles.
The reason the wheel fit so snug is because the Ram hub is a different size from the Chevy. Chevy is 78.1 while ram is 77.8.I’m still deciding if I want the black lugnuts. I thought I did, but not minding the chrome for now.
I went with the Yitamotor spacers this time. The Boras were $280, and the Yitas were $99. Exactly the same product. They did go on tight tho. The ID of the spacer goes onto the wheel hub smoothly, but the OD of the spacer hub is .005” larger than what the ID is, which causes the wheel to fit very snug onto that area. I just gradually tightened 3 lugs and allowed the wheel to pull onto the hub. I did the install myself.
The 1.500” spacers fit my wheels without trimming because there is a .580” deinep pocket on the backside of the wheel where the extra length of the lug fits into. I will include pics.
The overall width of the stance is around 1/2” narrower on the back vs the front. Based on my tape measure reading. The package deal I purchased was for 4 spacers, so I did not worry about getting a different set for each. You might look up the specs and get a better measurement, but I do not notice a big difference.
Looks great but you need some black lug nuts!
I agree. Love the setup! Also like the idea of black lug nuts. Do you have a link where you are getting the black lug nuts for our trucks?
For stock wheels: https://www.summitracing.com/parts/GOR-66147BDX
I wouldn't! You get what you pay for bud!!! So my question is; do you think 2" all around will be too much? Do you rub at all, and did you have to trim your stems using the 1.5" spacers?Those look great! Now I feel dumb for dropping $250 on the Boras!
