Until the dealership addresses the issue I can only speculate the hood is glued on and the adhesive is separating. Pressing down on the hood gives the indication it’s definitely installed in a climate controlled environment as it seems to be too small - it doesn’t naturally lay flush with dash. Adhesive is the only thing preventing a gap. Not good.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
