Gear swap?
AE_Ram19
I have the 2019 Ram Limited 4x4, at the time I purchased I could not find any with 3.92 gears... so I settled for the 3.21’s. I’ve been told on previous models the front axle is not serviceable therefore simple gear swap was not possible. Does anyone know if the 2019’s are still the same or can they be upgraded?
SColang22
They can be but nothing is out for the front end yet. There are a ton of threads on this already if you give it a search. Also if you want to upgrade I’d go with something smaller than 3.92 especially if your trying to run bigger tires
AE_Ram19
Thanks! I tried looking under suspension, power train etc and couldn’t find anything. But I’ll keeping looking. I figured someone besides me has had this come up by now.
SColang22
Use the search bar and check “gear swap”
Willwork4truck
SC
I suppose the question is why the swap? Unless its heavy towing or a big lift/very big tires, thats a lot of coin... pays for lots of fuel.
