285/75r18
Copperstate
Hey everyone,
I tried searching but didn't have much luck. I am leaning towards putting 285/75r18 (about 35") on the stock Rebel rims with a 2.5" leveling kit. Anyone have any pics of a similar setup? From what I have read, it should clear just fine.
Thanks!
I ran LT 295/70/18 on my Rebel wheels soley with my Mopar 2” lift and was just fine. Granted it was a lot heavier then my original size but definitely looked good.83D21173-97ED-4BD9-BBD5-3585E1AD0FBE.jpeg
Running 295/70-18 Nitto Terra's on my Rebel, 2" level kit.
275/65R20 nitro ridge grapplers.
Air suspension with off road group.
Thanks, Wheels Fuel Vector D579 Tires Cooper STT Pro 295/70R18 Exactly 34.49
Are those the same offset/backspace as factory? Do you have any head-on pics by chance? Looks great!
How much did it hurt your MPG city/highway?
Same offset as factory, Didn’t notice any MPG difference to say the truth I’ve only had them for a week now.
Awesome, can't wait to see it after the leveling kit. Hopefully it helps with the rub.
Actually there is no rubbing at all, Even before the leveling, It was the mopar mud flap that I installed earlier not the wheelhouse.
@kliffy77 I am looking into getting those exact wheels and am trying to decide between the stock offset vs +1 offset. Any issues with clearing the brake caliper with balancing weights?
Nobody? Somebody has to be running this size somewhere? Or maybe even 295/70r18?
Just for anyone else out there still doing research on this.
I just installed toyo open country AT3 285 75 18 with stock rims, stock rebel suspension and they fit, they do not rub anywhere, my biggest concern was the upper control arms but they clear them no problem.
Next will be a 2 inch front lift with bilstein 5100s, rear motofab 1 inch lift, and upper control arms.
I do not have the air suspension.
Made my mind based on the rebel rouser that TFL built for offroad. Although TFL left the stock upper control arms, which I find odd, and they didn't lift the rear, just 2 inch leveling kit.
I went with the 1 inch motofab rear spacers as well because my truck stock only has a 1 inch difference in height between the front and rear. And I don't like when it looks like it's squatting.
Cheers.
Cheers.
I’m late but I’m looking at the 285/75 18 so they fit I have level and a 1.5 inch lift in the rear
