RamBigHorn
 - Feb 21, 2019
- Location
 - Etobicoke, Ontario Canada
How can I tell which Axel Ratio my Truck has? It does not show it on my sticker.
	Register at mopar.com and look under Vehicle Equipment/ OtherHow can I tell which Axel Ratio my Truck has? It does not show it on my sticker.
I don't think the electronic locking rear differential is available with the 3.21 gears so I think RamBigHorn must have 3.96. Check build sheet to be sure.
If you dont see an additional charge for the 3.92 (I think it was $95) you have the 3.21If it does not tell you, then I would assume it's the lower number which is the base.
If you look at the '19 Ram 1500 sales literature, or the online ordering screens, you will see that the 3.21 non-limited slip axle ratio is standard across the line, with the exception of the Rebel. But, I looked at mine and the 3.21 axle is listed in the Standard Equipment column (far left).
Why it wasn't on yours I can't explain. However, I believe if it had the 3.92 axle it would've been listed under Optional Equipment (The 3.55 is standard with the Pentastar V6). By deduction I'm pretty sure you have the 3.21 ratio.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 011143 miles.
