hotsht333
 - Aug 24, 2018
Finally done big horn quad cab, just got my tonneau  cover , bed rug and swing case installed.
			Mopar Passion Red. https://www.amazon.com/gp/product/B01G45UT5A/ref=oh_aui_search_asin_title?ie=UTF8&psc=1A couple weeks ago I noticed that I have a tiny rock chip on the very front of the hood. I want to buy a touch up paint pen to fill it in but the mopar store doesn't have Delmonico Red. Is there another color that is close or do did they have a different name for it in the past?
Also, when transporting wood (pictured above) some of the green plastic wrap melted to my left exhaust tip and has now hardened. Does anyone know how I can remove the now hard plastic from the chrome? It is a fairly thin layer.
Thanks! I saw that one but thought it might be a brighter red for some reason.
That is great! Thank for taking the time to put all of that info together. It was very helpful. I will see if I can buy some at the dealership but if not, I will probably go with the bottle on Amazon.klail,
I have along with others received a small touch-up kit (bottle) from Manufacturer or Dealership??? I don't know which one but the box has the Dealerships name on through shipping "EPI Fulfillment". It is MOPAR, says its from Dealership.
I have Delmonico Red too--bottle has number 06102696AB and it says PRV in upper right hand corner of label on pen.
Ya might want to give your Dealership a call and see if they are providing this to you.
EDIT----I included the pics of the kit, it appears it is a gift from dealership (writing on my box is coverd with shipping labels) I received it beginning of March purchased truck end NOV.
EDIT AGAIN---Here is the paint code number info, its from 2018 but you get an idea now what to look for from MOPAR or dealership: https://www.dealers-mopar.com/resources/pdf/moparone/retail/mopar-touch-up-paint-2018.pdf
What’s your payload ? Specs of the trailer? How’s it pull? Looks great!
The payload is for the trailer, not the truck. The truck can tow 12,000 pounds. If you are careful where you put things, it does not affect the tongue weight muchhow did the lane assist make it sway a bit ??
i would think your payload sticker should say something like 1250 # so i guess you can not haul many toys and be legal
really ... you really do have a very special trailer ... it is not the lane assist that causes the sway, i would think the WD hitch is not set up right ... as far as towing 12,000 #s i would say NOT with a TT ... maybe a flat bed trailer where you can shift the weight and lessen the tongue weightThe payload is for the trailer, not the truck. The truck can tow 12,000 pounds. If you are careful where you put things, it does not affect the tongue weight much
