Tail Light Bulb Sizes??
rosedaleny806
Hello All, New Ram owner. I was havign difficulty finding the size for the actual brake light in the tail lights. I have read 3157, 3156 and 7440. So im in a bit of a bind regarding this needless to say lol. I now the reverse is 7440. Can anyone help me out? what is the brake bulb size. Non Projector/LED tail lamp model
LASFIT LED's all around...
White cargo lights: https://www.amazon.com/gp/product/B079M2QPPL/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Red 3rd brake light: https://www.amazon.com/gp/product/B07CK1NQQ8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Brake lights: https://www.amazon.com/gp/product/B077PR5B8G/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Reverse/backup lights: https://www.amazon.com/gp/product/B077PQWQR2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I've got all these in my truck. Super easy installs, no error codes, very bright.
Unfortunately, I've not been able to find ANYWHERE the kind of bulb the rear turn signal is.
For the cargo 921 you need 3 bulbs
LUYED 2 X 1550 Lumens Extremely Bright Error Free 921 912 W16W 3030 24-EX Chipsets LED Bulbs Used For Backup Reverse Lights, Xenon White https://www.amazon.com/dp/B01LX4FMD1/ref=cm_sw_r_em_apa_i_M0yGCbMH80YGR
Reverse lights 7440
Auxbeam Extremely Bright T20 7440 W21W LED Bulbs 5730 Chipsets 33SMD Light Bulb Super White for Reverse Light, Back Up Light, Tail Light, Fog Light, Turn Signals Brake Light (Pack of 2) https://www.amazon.com/dp/B07414XVKT/ref=cm_sw_r_em_apa_i_T1yGCbCQ1T82E
Super bright!
Hey guys I've having a difficult time finding led headlights low beam + high beam and fog lights can someone point me to the correct links to bulbs that fit.
I bought a set of LEDs but there too long and hit the reflector in the headlight assembly.
For fogs I have these installed: H11 size switchbacks https://www.amazon.com/gp/product/B07F2YPT37/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
For high beams I have these installed: 9005 size https://www.amazon.com/gp/product/B07JQ6YTJB/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Both installed easily and fit with no issues. Dust covers were able to screw back on.
Waiting for another week or so when LASFIT comes out with their new H11 headlights as seen here:
They have other install videos on Youtube of the bulbs I listed above.
Thanks! For the fog lights...what are switchbacks I've never heard of these before what is it that they do?
If you turn the fog lights off and then back on they will look like the factory fogs (that yellowish halogen look), then off and on again and they will be bright yellow, then off and on yet again and they will blink yellow like hazard lights, then back off and on again to be LED in 6000k. So pretty much 3 different light colors with the hazard option. Here is a video:
How does this effect the auto-on feature of the fog lights when turning?
Works exactly like your existing fogs. The only difference is you can toggle the different light colors by turning the fogs off and on with the switch.
thanks for the heads up!!! that signal bulb is strange. i have never seen it.
