Build Sheet Oddities
Edwards
TX
Slow day so I'm browsing others' build sheets and just have to ask if anyone can explain any of these:
From a 2019 RAM 1500 LIMITED 4X2 :
Rotary Shifter-Bright - what, they make a non-bright version?
Upper Active Grille Shutters - shutters are only up top, no lower ones?
Accent Color Shark Fin Antenna - black is an accent color?
Rear Wheelhouse Liners - seems odd they list this and separately "MOPAR Rear Wheel Well Liners"
Full Size Temporary Use Spare Tire - never heard of full-size temp use but then in optional it lists "18" Aluminum Spare Wheel"
USB Host Flip - found a good description here
FAM: DT TRACKING: 80110T43 MY:2019 - never seen anything like this on any other build sheet
Special Scheduling Condition VII - ?
firecadet613
Only thing I can attest to is the spare - it's a full size tire but not a normal tire. Definatly a temporary tire. It's been years since I've used a spare so not to sure I'll swap it out to a regular tire...I'd just be paying it forward to the next guy who owns my truck!
I'm only aware of the bright shifter knob, no other knob. I was hopeful the shark fin antenna was painted - but as you see they are all black!
The shutters should be over the entire grill - on my F150 it had uppers and lowers (lowers were over the intercooler). I haven't drilled into my build sheet that much to notice if the rear wheelhouse liners are on their twice or not...good observations!
Edwards
TX
Thank you! I've not seen that and it clearly explains the build sheet wording.
alacombe
Real wheel house liners are an add on and an additional cost. They are not stock
My spare tire is a full size tire and is a "normal" tire. Only reason being is that I got the off road package which comes with a "normal" full size tire. Same brand also.
Edwards
TX
The rear wheel liners are standard on Limited. I just found it odd that they were listed twice like maybe they may have another supplier in mind.
@alacombe, what wheel came as your OR Package full-size spare?
alacombe
My off road package provides me with full size 20in Faulken off road spare which is the exact same tire on all my other rims.
alacombe
"Special Scheduling Condition VII" This means nothing special its just an FCA code and its on several other members build sheets on this forum. Previously discussed.
Edwards
TX
I get that you have the same Falken tire, but what is the spare wheel? Is it a 5th 20" wheel (like on the four corners) or is it a generic steel spare wheel? Just wondering since they only claim "full size spare."
DL Parts
If you have a the VIN for the pickup I can gladly tell you if it is a steel wheel or the same as the other 4.
alacombe
its a steel wheel spare with the off road package
Limited
Houston, TX
My Limited has an 18” aluminum spare wheel per the build sheet. I have 2wd so no off road package.
