Stock wheel weights
thcmas35
Tracking order
Tracking order
MN
Does anyone know what the weight of the stock 20" wheel/rim is? I can't seem to find it and would like to compare the stock setup to an aftermarket wheel that I am looking at.
Also would be interesting to know what the weight of the 22" inch is as well.
billyraff
I was searching for the same thing, My laramie has the sport rims, but it would be interesting to see the weights of the whole rim lineup
Billet1500 4x4
California
35 lbs if Bridgestones tire information is correct for the 275 55 20 HL alenza weighing 38 lbs. A complete assembly weighs just shy of 73 lbs for the 5 spoke Laramie 20x9. I weighed mine because I wanted to know the same thing. I can't say for any of the other factory 20 inch wheels offered or wheels of any other size.
DavidNJ
This is the Falken specs for the OE tires: https://www.falkentire.com/oe-tires/wildpeak/t3wa
Model/MakeItem NumberSizeLoad IDService Desc.Approved Rim Width (in)Measuring Rim (in)Overall Diameter (in)Overall Width (in)Revolutions Per MileTread Depth (/32in)Tire Weight (lbs)Max Load (lbs)Max PSI (Cold)U.T.Q.G.
2019+ RAM 1500 (4x4 Off-Road)59000080LT275/65R18C113/110S7.5 - 9.58.032.111.164815.048.9253550-
2019+ RAM 1500 (4x4 Off-Road & North Edition, 3PMSF)59000570LT275/65R18C113/110S7.5 - 9.58.032.111.164815.048.9253550-
2019+ RAM 1500 (4x4 Off-Road)59000090275/55R20SL113T7.5 - 9.58.532.011.365314.045.3253551500-B-B
2019+ RAM 1500 (4x4 Off-Road & North Edition, 3PMSF)59000580275/55R20SL113T7.5 - 9.58.532.011.365314.045.3253551500-B-B
These are their retail tire sizes in those wheel sizes:
Rim DiameterItem NumberTire SizeLoad IDPly RatingService Desc.Approved Rim Width (in)Measuring Rim (in)Overall Diameter (in)Overall Width (in)Revs Per MileTread Depth (/32in)Tire Weight (lbs)Max Load Single / Dual (lbs)Max Pressure (psi cold)U.T.Q.G.
18" 28034901275/65R18SL4116T7.5 - 9.58.032.110.96631447.4275651660-A-B
28030803LT275/65R18E10123/120S7.5 - 9.08.032.110.76511860.23415 / 308580-
28030703LT275/70R18E10125/122S7.0 - 9.08.033.411.06241861.03640 / 330580-
28030827LT285/65R18E10125/122S8.0 - 108.532.611.36421864.23640 / 330580-
28037333LT285/75R18E10129/126R7.5 - 9.58.034.811.25991865.94080 / 375080-
28037327LT295/70R18E10129/126R7.5 - 108.534.311.66091868.14080 / 375080-
28037122LT305/65R18E10124/121R8.5 - 11.09.033.612.06231966.63525 / 319565-
28030126LT325/65R18E10127/124S9.0 - 12.09.534.613.06052076.73860 / 352565-
2803733037x12.50R18LTE10128R8.5 - 1110.036.612.56391979.4397065-
20"28034021275/55R20XL6117T7.5 - 9.58.531.911.16611348.1283350660-A-B
28034003275/60R20SL4115T7.5 - 9.58.033.110.86401347.8267951660-A-B
28030128LT265/60R20E10121/118S7.5 - 9.58.032.510.26401858.23195 / 291080-
28030120LT275/65R20E10126/123S7.5 - 9.58.034.110.66111866.13750 / 341580-
28034121LT285/55R20E10122/119T8.0 - 109.032.411.26421858.23305 / 300080-
28037329LT285/60R20E10125/122R8.0 - 108.533.511.26221865.53640 / 330580-
28037326LT285/65R20E10127/124R8.0 - 108.534.611.26031867.73860 / 352580-
28037328LT295/60R20E10126/123R8.0 - 108.533.911.66141869.43750 / 341580-
28030952LT305/55R20E10121/118S8.5 - 11.09.533.212.36261971.03195 / 291065-
28030125LT325/60R20E10126/123S9.0 - 12.09.535.412.85912083.83750 / 341565-
2803711835x12.50R20LTE10121R8.5 - 11.010.034.612.56032076.1319565-
2803733137x12.50R20LTE10126R8.5 - 11.010.036.512.55701977.8375065
Note, the 275/55-20 is the only non-LT Load Range E size in their regular tire.
They are not the same tire, retail on the left, OE on the right.
djjr50
Anyone know what the weight of the factory 22" limited rims?
The factory tires are 45lbs according to TireRack.
Eric_N
Has anyone found out the weight of theses? 22”
RamMyVag
Hey. What's going on just curious .... On a road trip don't have access to the truck , wondering if anyone knows the weight of the stock 18" wheels.
Jako
Borough of Parks
I believe the Bighorn wheel is about 72 lbs total
OC.13
New Mexico
I weighed mine before I got my new set up. The total weight of my oem 18s with goodyear Wrangler tires was 66 pounds. According to the Goodyear website my stocks weighed 39 pounds. Puts bighorn wheels around 27 pounds. Hope that helps.
JBV
i did not realize the OE Falken LT tires were actually different than the retail versions. i did some googling and it looks like the OE's are just a lighter, 6 ply version (which is the C rating) vs the retail in the same size which jumps a grade all the way to E and 10 ply. and these are 10 pounds heavier per tire! i imagine they are all the same compounds and tech as far as construction goes. one thing about tires, the closer you look, the techier it gets and you can really go down the rabbit hole.
