THEY FIT 35X12.50X20 NITTO TERRA GRAPLER G2
Yes OP you can’t just post that and not give any details lol...
^^^. Question, is your size equal to doing a 35x12.50 ? Just curious as we seem to not be hearing anything back from the original poster.
Yes, we tried both the 35/12.50/20 and the 295/65/20 Discoverer STT Pro tires. The 295 is about a quarter inch taller and narrower than the 35. The stock wheels put the tire really close to the upper ball joint, so I decided on the slightly narrower tire for more ball joint clearance.
I find these conclusions very surprising.
On my Limited, I just installed Ridge Grapplers in a 33.5 x 12.5 x 22 and they rub like crazy at high steering angles in Entry/Exit mode.
Will the 295/65/20 Discoverer STT Pro tires fit on a 2019 Ram 1500 with the sport appearance package with the standard suspension without air ride? Thanks..........
I only know from my truck in driving with it in a lower setting like aero mode it doesn’t rub. In entry/exit mode it doesn’t rub, but I also don’t drive it in that mode, so I bet it probably would if you flex the suspension.
I do know that these tires are much louder than the stockers, and I’d even say louder than the 325/65/18 Fierce MT’s on my Colorado.2CB15C49-70B1-4F2F-9CF7-EF6B112C846B.jpeg
Thanks for your responses. Does anyone know the largest, wide and beefy tires that will fit the Ram 1500 Laramie with the sport appearance package and standard suspension with the 20 inch wheels that wont rub?
1. Where are the PICS?!?!
2. How much trimming?
You can most likely fit up to 33's. 12.5 wide may require a 1/4" spacer to prevent rubbing on the UCA.
I doubt it too. I had to do a 3.5" lift and 1/4" spacers for 35/12.5.
