can someone post a photo of the in-bed 120v outlet?
mike_ct
my bighorn is not equipped, but there is a unused wire harness with plug behind the panel where the switch would be located..I'm curious where the outlet goes in the bed, and if any wiring is hiding someplace that can be finished.
Depending on where you found it, it could be the wiring for the bed light switch, located on drivers side near taillight.
I do have that..I'm guessing the plug is near that location as well?
my bed lights come on and off with the cargo light switch in the headlight switch assy.
there is a mystery plug, behind the parking brake + adjustable pedal switch panel..the only other switch I've seen located in that switch panel, is the one for the rear outlet
I thought the 120v outlet was with the rambox and there will be an inverter switch by the power pedals switch.
Yes, I have the Rambox and that switch controls the power inverter for the Rambox outlet.
