Put high octane in for a tank or so, your passing ability will increase. You are running under spec. You aren't damaging anything by running 87 but you are lowering your horses, and we're your other Ram's Limited also? Mine weighs over 6,300 lbs. Weight directly affects your acceleration and is often overlooked (even by myself)
No thanks. 87 is acceptable and it's what I have run in every other Ram I have owned. Like I've said, my current acceleration is not unacceptable; it's just not as quick as my last 2 Rams.
Not sure of the curb weight of my last 2 trucks, but there may have been a difference. My 2012 Big Horn and 2017 Laramie were both quad cabs and my current truck is a crew cab. However, I am permanently carrying about 200 lb less in tools, recovery equipment, etc under the tonneau due to the smaller bed.
Edited to add: According to Edmunds, a 2023 Limited crew cab weights 100 lbs more than a 2017 Laramie quad cab. I'm sure I've reduced weight by at least 100 lbs due to the smaller bed size. I think the 23 uses more aluminum than the 17.
