Wire Harness behind HU.
depending on wht you are working with you may just want/need the anc bypass harness
I don't have the ANC I just have the v6 sorry I should have specified that.
Sent from my LM-G820 using Tapatalk
Having issues tapping in behind the HU. All wires are tapped in correctly according to the 52pin harness I referenced. I was assuming the Screen had the amp built in for the radio. I am getting what I would call a ground out cancellation for the sound. If this is not correct location for the amp can anyone help me locate the stock amp for the radio.
