Will this set up will work?
Vegas1500
Has anyone had success running 305/55r20 on a 20x10 -18 wheel without a leveling kit? I have the air suspension so I can’t level. I do have the Off Road Package so I have an extra inch. I’ve read through a lot of posts, but I’ve haven’t seen anyone with this specific set up.
Following. I want to run a 20x9.5 -18 with a leveling kit. Did you find any info?
The best info I found was searching on customoffsets.com where there are a couple of pictures in the gallery showing trucks with this set up.
that is the set up I wanted also, my local guy said I should do 20 x 9 with a 0 offsets. 305/55/20 would be the largest tire. This is the setup I think I'm going with
I'm also on stock air suspension with off road package
Instead of -18 I’m going with a +12 offset. It will look exactly like this but I’m doing black rhino arsenal wheels in the same size as the picture
This setup
