will they fit
hardluck
i have a 2020 ram 1500 4wd 2inch level strut in the front will a 20x10 -19 offset with a 35/12.50r20 fit? sorry if this has already been discussed new here
No it won’t, to fit that you need a 3.5 inch kit really and then it still requires a little trimming / fender molding. If you want the -19, I’d recommend a 33x12.5 or 305/55
Thank you
No problem. Lots of threads on 3.5 lift options, from bilstein with readylift, readylift, or mopar + some method to level the front. But I’d recommend a level and a smaller tire...cheaper unless your dead set on 35s like I was!
