You should have no issues clearing the 33’s height wise. I am running 33x12.5R22’s with just a level and it clears. But, my wheel offset was a bit different than stock, so I added in spacers to clear my UCA’s a bit more. Heck, with that 3.5 lift, you could put 35’s and clear! Good luckI just purchased a 2020 1500 grey metallic night edition crew cab. I want to put the rough country 3.5" lift with the new struts and shocks and also add Nitto ridge grapplers 33x12.5x20 stock wheels. Will it rub or need trimming?
Good deal thanks for your comment.You should have no issues clearing the 33’s height wise. I am running 33x12.5R22’s with just a level and it clears. But, my wheel offset was a bit different than stock, so I added in spacers to clear my UCA’s a bit more. Heck, with that 3.5 lift, you could put 35’s and clear! Good luck!
Do you know of any good photo galleries that I can see the two comparison?Should have zero issues clearing 33's, and IMO, the 33's will look small on a 3.5" lift
Yeah it comes with new UCA's. Rough Country says it wont be an issue but sure they just want to sell.Does the lift come with different UCA’s ? I Had to put a 1/2” spacer on my front to clear with my aftermarket UCA’s and stock offset. Totally different setup than what you’re looking at but I did‘t bother to check first…. And I’m only running 11.5“ width wheels…. Usually the manufacturer will list what size wheel and offset is recommended.
Looks great. I will def have to get 34's thanks.I have the RC 3.5” lift with N3 struts. I did add Icon 1.5” rear lift coils. Here’s mine with LT275/65r20’s basically 34 x 11.5r20. The 33’s will look small. View attachment 143175 View attachment 143176
