Will 35x11.5x18 fit with OEM wheels?
Mr. Sunshine
I was looking to put some Falken WildPeak AT4/W (35x11.5/18) Specs are 34.9x11.9 and will be going on some RHO/TRX 18" rims that will on my 2022 Ram 1500 Larmie . I'll be adding Eibach Pro Truck Stage 2R kit and aftermarket UCAs. Question I have is will they clear the UCA with that setup? I seem to find conflicting info on it as was hoping for some answers.
I had TRX wheels with factory 325/65r18 and you need a minimum .75 spacer or else the tire hits the control arm. I put 1.5 spacers on for a little poke.
What psi are you running?
So that's around a 12.8 wide tire and your saying you needed at least .75" to clear.. putting it at 12-12.1 max w/o spacers before hitting UCA. Sounds like the 35*11.5 will be close based on the 11.9" spec on the Falken site. Wonder in a 285/75/18 would be safer bet or I could run a .375 to .75" Bora spacer to get the needed gap for UCA. Just don't want to much poke.
