AA1mike
- Apr 17, 2021
any experts out here? is this correct? i just learned this a shot while back. i am still trying to pic a lift and i have factory 18x8 5 inch backspacing +19 offset rims.
when you add wheel spacers you decrease backspacing.
example..2 inch spacer with a factory wheel with 5 inch backspacing you will end up with a backspacing measurement of 3 inches.
now if the spec is minimum back spacing of 5 inches for the lift kit then this will not work.
now your calipers and or your control arm have interference.
backspacing and offset are different.
offset is the distance from center of the wheel.
backspacing is distance from wheel mounting surface to outer lip of the wheel.
