Which Suspension Maxx links for leveled Rebel?
Cygnus A
There are 2 options for end links :
2-2.5" Leveled Sway bar links 2019+ RAM 1500 (SMX-1319L) :: SuspensionMAXX (2-2.5 inch)
3-3.5" Leveled Sway bar links 2019+ RAM 1500 (SMX-1319X) :: SuspensionMAXX (3-3.5 inch)
I have the Eibach Pro Stage 2 installed which claims 2.2 inch lift on Rebel, but 3.2 inch on other models. What I assume is that since it fully replaced all coil overs, that the "true lift" is the 3.2 inch and I need the SMX-1319X end links.
Anyone have experience with these 2 different links?
I have a 2019 Laramie Longhorn with the ORP. I just did the Eibach kit install minus the rear eibach springs. I ordered the 3-3.5" because it is referencing to ram 1500 non-ORP or non-Rebel. I am installing them this evening.
id go 3”, Factory level on Rebels are 1” over factory non ORG group. So if you’re adding a lift that claims 3” on nonrebel and 2” on Rebels.. your at 3”
go with the 3"
you're at 3" over non-rebels so there's that. the end link measurement referencing to non-rebel, non-orp trucks, as it doesn't specify if it's referencing to rebel or orp.
I have Fox 2.5 at its factory default height, 2" over non-rebel, non-orp and 1" over stock rebel or orp trucks.
chose to leave it at that for maximum suspension travel, since jacking it up to the max will reduce droop and suspension travel.
i went with the 2-2.5" set and it sat fine. sway bar quite parallel to the ground as it should.
