Which is the Parking Light wire in Turn Signal socket?
JCR1500
New Hampshire
Hello, I switched my wife's halogen headlights to AlphaRex LED headlights in her 2014 Bighorn and have the Parking Light Out message. Talked to Alpharex and they sent me a pair of resistors to install. My question is in the factory wiring harness for the turn signal wiring where the parking light wire is, which wire is it? I know 1 wire from the resistor goes to the ground which is black but I don't know which of the other 2 wires is the parking light wire which the other end of the resistor is to be wired to. I am thinking that the center wire is the parking light wire from google searches and such but thought I would ask you guys.
Thanks.
BTW, if you are thinking of converting to LED headlights these AlphaRex LUXX series look awesome and was an easy install. The front end of a 4th gen is way easier to take apart then it was on my 2020 Bighorn so don't get intimidated if you plan to do this swap.
