on my 2020 ram limited when cold the rear right outside handle won’t budge. When I did get it to pull, then the rear door would not latch shut. once I put it back in my heated garage and it warms up, then it works normally. Is there a known issue and/or a TSB for this issue? Only happens when below 32F. Guessing there is water in the door latch cable freezing up.
