Just looking for some insight after scouring the threads a bit. I have a 2020 Bighorn 5.7. I am thinking of swapping the wheel out. Currently I have the 5 star stock 18's. 275/65/18. Thinking of going with a 22 inch. I have a set of GM wheels in mind I would like to run. Specs for comparison.
GM wheel
22x9
6x5.5 pattern
+28mm offset
78.1mm center bore
Ram wheel
22x9
6x5.5 pattern
+19.05 offset
77.8mm center bore.
Being the GM has a slightly higher center bore will that .3mm cause damage if I do not find a .3mm hub ring? It's been crazy hard to find one that size. Also will I have any issues with any type of rubbing due to the higher offset? I would be running the factory Ram 22 inch tire size.
Thanks in advanced for any info or advice.
GM wheel
22x9
6x5.5 pattern
+28mm offset
78.1mm center bore
Ram wheel
22x9
6x5.5 pattern
+19.05 offset
77.8mm center bore.
