Wheel flare clip removal
Troublesome
Anyone have suggestions how to remove the wheel flare clips that are on the 2020 Laramie ?D02F4FB6-D515-41D8-8637-FD9C0A7EE281.jpeg
Just had my wheel flares off, the clips pull off the fender fairly easy and stay on the flare except for the front 2. I start pulling off from back(towards door) once you get to the last 2 towards the front just push up on the flare. The front 2 will slide out from the flare and stay in the fender. Just rotate the 2 clips 90 degrees and pull them out and slide them back onto the fender flare.
So you didn’t remove the tires and remove the wheelhouse shrouds to depress the clips from behind?
Nope not all, just remove the screws on bottom side of flare.
Here is a pic of one removed so you can see how it works.
From what I'm seeing it looks like the Laramie has holes in the fender??? Am I correct??? So no removing the flares to smooth up the lines and make waxing easier....hassen frassen @#$%^&.
You are correct, if you have a Laramie that comes with factory fender flares the sheet metal for the panels have holes that these plastic tabs clip into.
Whats the best way to remove the clip if it's still in the fender itself?
