I have a 2022 Ram 1500 Stock. No Air Ride. I want to do a 2 or 3 inch level kit up front. I was hoping to get at least 35's 12.50's. What is the biggest wheels and tires I can get under it? Please let me know.
with a level up front you can clear the taller tires but the big concern is wheel offset. that is the key to making it all work. i have 0mm offset on 20x9 35x12.50xr20 and have a good bit of space between tire sidewall and UCA i think if you run a +18 offset you will run the risk of hitting UCA's
take all this i say with a grain of salt. but from my findings some where between +18 and 0mm is the sweet spot a common offset also is -18 or -12
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
