Wanted to get peoples opinions on two possible wheel/tire setups that I’m considering.
Truck is a Built to Serve in Ceramic Gray and currently has the stock 20” technical gray wheels with 275/55R20 Falken all-terrains.
Option one is to keep the current wheels, but go up to a 285/60R20 tire. Probably the Toyo Open Country AT3.
Option two is to ditch the stock setup and put on a set of the Limited Night Edition 22’s with a 285/55R22 tire. Again, probably the Toyo’s
Truck has the off-road package which has an increased ride height of 1-inch. And I’ll be leveling the front. Truck won’t be seeing much off roading.
Thoughts? Just want to keep it to these two options.
thank you!
thank you!
