What to do with ParkSense after upgrading tires
eclipse5302
I've got a 2019 Limited, and after reading about the various tire sizes available, went with 285/55R22 Toyo OC AT3. Went to set my tire size (used TazerDT and AlfaOBD), and found like many others that ParkSense gets disabled above 2557mm.
My tire size as measured on the ground is 2670mm, and setting it that way makes the speedo perfect. But I'd really like ParkSense back. The TRX has bigger tires and ParkSense, so it must be possible?
What is everyone doing after going bigger? Just ignoring the broken ParkSense?
Most times, I don't correct the speedo. I check a GPS for true speed and just be conscious of it. Doing so also keeps your odometer showing less than actual miles. I did have a pulsar in my 2019 that I used to correct the speedo and my parksense wasn't affected. That was with 35s.
It seems like some can go high enough without erroring out and some can't. I've seen mentions of a limit of 2710mm, which I would love...but mine won't go past 2557mm.
