What size lift??
cstorts
Hey guys my first time posting on here hope you can help me out.
I have a 2021 1500 4X4 North Edition and I'm looking to lift it up and get bigger tires. I would love to get 37" tires so what size lift would I need? Would a 3.5" lift work?
what i have read and saw it was 6 inch lifts with cutting and bending 😂 for 37
Dang that's more than I wanted haha so max would be 35" tires with a 3.5" lift?
From the threads i read i think your goood with 3.5 maybe slight rubbing and fix with some minor things
35” you need at least a 2” with stock to 0 offsets, 3.5” for -18 to -24 offsets
37” you need at least a 6” lift, and still requires some trimming/cutting
+1 on 37's needing 6" lift and a little nip/tuck...
I'm trying to also figure out what size/brand lift. I have 33s -44 offset on factory air ride
with a 3.5" I was able to do 18x9 -12, with 295/70R18 (approximately 34.3 X 11.9) with no rubbing
I have the motofab 2.5" leveling spacers on front, 1.5" spring perch spacers on the rear and have 2" wheel spacers all around. I run the stock Rebel wheels with 295/70/18 tires (34.25") and had to do some slight inner fender trimming. I attribute the trimming to the 2" wheel spacers.
I believe your North Edition has the 1" ride height advantage over other models like my Rebel so the results should be the same.
yall think a 305/70r18 k02 will fit with a 2 inch mopar lift with minor trimming?
