Water leaks at rear of cab as repaired by professional Water leak tech
Nuseal
Third brake light is main issue. Remove factory gasket and clean all the way to plastic. Prep with denatured alcohol and run round 5/16 butyl tape around it. Heat on dash before pressing it in. All surfaces must be clean for this. Seal mounting screws with butyl tape top 1/3 of threads. Rear window track drains can become clogged. Use a paperclip to clean. Lower middle seal on rear glass movable window allows too much water into tracks. Clean and run a bead of Black automotive silicone across it all the way to the edges. Rear cab ventilators behind rear seat are a huge leak. replace with updated version.
I work in Northern Virginia Woodbridge Manassas and Fairfax If you would like me to fix your leaky ram.
