Want to reverse level, what airbags should I use?
qdude79
Considering Maxtrac rear springs for a reverse level. Question: would the same Ram Airlift 1000 bags work for them, or do they require Durango bags? '22 Longhorn Crew Cab 2wd Diesel, btw.
I used Durango bags. Normal are way too long.
Thanks for the response. What year Durango? Do you have a part number?
You could get the HD versions if you think it's necessary for your application. My trailer is only 350-380 lbs of tongue weight so I didn't need them.
Not familiar. My tongue weight will be between 600-700lbs and possibly a quad in the bed. Can you point me in the right direction? Thanks again.
The red ones are good for up to 1000 lbs of leveling force. With the right WDH, you should be okay.
