Want to restore to factory ride from 2" Mopar lift. Should I....
Lungs414
I did the lift about 9000 miles in. At 65000 miles it needs work. Struts are shot and I have original struts and shocks. Was thinking of just putting them back on but since the ride is so bad I figured I would replace the UCA and LCA, and tie rods and end links. Because why not since it will all be apart. I want the original ride back anyway, no off-roading. I have the original UCA but not sure If there would be an issue considering the LCA would have 55000 more miles on them. So if I change the lower to new why not the upper. I saw Mevotech makes a Supreme and a TTX version. If I went with the supreme I would save over $200. Is there a huge difference between the Supreme and TTX for my usage?
I know if I go down this rode I should probably change the struts and shocks but I would like save some money if not really necessary to use the originals provided they don't go bad being on a shelf for 4 years inside.
Thanks in advance for any help
