seansmd
I added a Bulletpoint mounting wireless charger to my truck(2023 limited with 12inch UC5), I noticed the charging cycling on and off and tought it was the mount/phone/case/wire, etc. Turns out the head unit detects a device turns on power but then does not connect with data and cycles off and repeats. I verified this with all the wiring and mount using a wall wort in the inverter and it all works fine phone/case/mount/wire.
I have ordered some data blockers to see if this will allow the ports to be used without needing to add a wall wort in the inverter to feed the wireless charging phone mount.
