Seeking some insight in Upper control arms I have ordered a set of JBAs hoping these are good quality also seeing if anyone has used white line or superpro or should I look into BDS or ICON instead?
JBA's are about the best of the low end UCA's. They are about equal or better than BDS. Icon is top of the line with Camburg, King, Total Chaos, and others. It is totally budget driven. If you want the best you gotta pay like anything else.
I'm running the Zone Off-road UCAs. They are probably some of the strongest built available. Tubular arms like the JBAs won't be as strong. But I really like the JBA control arms because of the bolt on ball joints. Replacing pressed in ball joints is a total pain in the *** and pretty much requires you to completely remove them to press the ball joints out and back in. I got the Zone off-road ones because I found them NIB on local Facebook marketplace for a steal.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
